Old 29th September 2010, 09:54 PM
Oli18's Avatar
Oli18 Oli18 is offline
Default For Sale: D3 S8/W12 front calipers, red stuff pads and discs
Hi,
So after a really painful few months of finding a brake setup that i liked, getting bigger wheels to fit them and then taking the trip up north to Ben to have the brakes fitted, it turns out that my early FL setup (also found on many PF models) won't allow for the calipers to be fitted...even if the caliper mounts are modified.
So i'm forced to sell this set up for now and just want to get back what i paid for it - 550 quid.
The setup contains 2 S8 calipers, red-stuff pads and enormous 385mm grooved and drilled discs all in great condition with the discs and pads only having 4k miles on them.
They will fit some later D2's without modification as you can see in the tread here:
Naturally, they will fit the D3
I will be at ADI so if anyone is interested in these, please send me a PM...
Thanks,
Oli
Audi A8/S8 D2 Flickr Group
Old 30th September 2010, 12:01 AM
damn really sorry to hear they cant fit after all that Oli
I guess that probably rules mine out too as an early facelift. . . but id be interested to talk to you and see. . .
On the plus side the wheel upgrade still looks great
Old 30th September 2010, 09:02 AM
Night Train's Avatar
A purely academic question here.... would they fit a late pre facelift S8?
I say its academic as I've just replaced all four corners with original Audi Parts (vented all round, and done less than 1K miles since) and I suspect a wheel diameter upgrade from the OEM 18" Avus's may be needed to fit the D3 brakes as well.
Other vehicles
Oh Yes....... The '98 PF S8!
Old 30th September 2010, 11:12 AM
A8 Doc A8 Doc is offline
Just re-shoed the D3. Gutted!!!
Old 30th September 2010, 03:23 PM
Bagsy!
Can you PM me details on how to pay and stuff?
Mike - Would you be OK picking these up for me from Oli?
Hang on... Quick edit!!! Will they fit inside 19" wheels? Probably won't do it if they need 20s.
Old 30th September 2010, 03:32 PM
Yes Richard. I will pick them up............ Muhahahahah
The will fit under 18s as the calliper is a lo profile type.
If you don't want them Richard I will have them.
Old 30th September 2010, 06:06 PM
I did get permission for them, so should be OK.. But if she goes spare when they arrive, I might have them on offer again
Old 30th September 2010, 06:47 PM
So I mustn't tell yer Missus that you have spent £1500 on them!!!
Old 30th September 2010, 08:47 PM
Oli18's Avatar
Hi,
Neil got in there first but only if they fit with PsYcHe with 2nd dibs.
Neil - i believe they will only fit if you have this brake setup:
Let me know if this is the setup you have - if not, i will let PsYcHe have these.
Thanks,
Oli
Old 30th September 2010, 09:17 PM
Basically they will only fit if you already have the Teeves set up.
