Old 18th May 2013, 07:54 AM
Default Bumper off....
...and in the paint shop for a couple of days. So I took advantage of the easy access to the tailpipes and got the Silverline (a kind of Dremmel) to work with a soft pad and Autosol.
Very pleased with the results!
ID:	6037   Click image for larger version
ID:	6038   Click image for larger version
Old 18th May 2013, 08:16 AM
Very nice indeed....methinks you're setting a high bar for Black S8's at the meeting. Not sure I can get my tailpipes to look that shiny.
Old 18th May 2013, 08:46 AM
just what I was thinking too (probably best not to tell you what my other half said when I showed her the pics) it does look like a very good result there Jim
Old 18th May 2013, 09:07 AM
Oli18's Avatar
Oli18 Oli18 is offline
Very very clean!
Audi A8/S8 D2 Flickr Group
Old 18th May 2013, 09:17 AM
Great stuff for annual meet and the next 6 months on.
This is **bare** metal now. Stainless steel hopefully. Now think about all the salt in winter -- job needs to be repeated at least annually. I wonder if the thing was designed to be removable. If yes, I'd seriously think about sparkling silver powder paint.
Old 18th May 2013, 11:48 AM
Better not show her these then. I had the front wheels off to give them a good clean and thought I might as well clean the calipers and touch them up, and wax the wheel arches!
ID:	6040   Click image for larger version
Old 18th May 2013, 11:51 AM
Very nice! I may have to get one of those dremel tools. What kind of pad did you use, and brake cleaner too?
I was almost going to attack mine with a green dish-washer pad, but seeing as it scratches my frying pan, I didnt want to risk it on the exhaust tips.
Old 18th May 2013, 11:57 AM
I used a soft material pad on the 'dremmel' with lots of Autosol. And I used wheel cleaner on the calipers
Old 18th May 2013, 05:57 PM
What's next? Wax gentlemen's area?
Old 19th May 2013, 08:15 AM
might be worth spraying some clear lacquer on them now to help protect?
