Old 15th February 2009, 10:58 AM
Default Fault Code 16684 and 16689 Misfires!
Out for a drive yesterday when Engine management and cat light came on:
Sunday, 15 February 2009, 10:59:22
VAG-COM Version: Release 409.1-S
Control Module Part Number: 4D0 907 557 N
Component and/or Version: 4.2L V8/4V MOTR AT D01
Software Coding: 04373
Work Shop Code: WSC 02324
2 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16689 - Cylinder 5 Misfire Detected
P0305 - 35-00 - -
Misfire is very noticable.
So swapped coil pack on 5 with 6 and fault stays with 5. Swapped coil pack with 7 and fault stays with 5.
Swapped plugs between 7 and 5 and fault stays with 5.
What do we think next please? Ignition Control Unit? Broken Wire? Dont think it's injector as Cat light coming on indicates unburnt fuel!
Mike
Old 15th February 2009, 11:26 AM
My money would be on an ignition amplifier fault - Its quite common.....
They are on the left side of the engine bay towards the top.... There is a pair of them. You can easily swop them over and the fault will almost certainly move onto a different cylinder proving one is faulty....
For giggles, you can run the engine with one disconnected.... By 'eck 4 cylinders sounds rough
Old 15th February 2009, 11:34 AM
A cheaper alternative to LPG?
Old 15th February 2009, 01:27 PM
lol
Old 15th February 2009, 01:29 PM
Yes. That is my next test. If it's that I'll contact David.
Old 15th February 2009, 04:10 PM
Right, been out, done that and.....
the misfire has gone!
Not jumped to the other bank, but gone. Dirty/loose contact?
Can't take it for a test drive yet as been on the pop at lunchtime. Will give it a blast tomorrow. Happy though
Old 15th February 2009, 04:31 PM
Oli18's Avatar
Oli18 Oli18 is offline
Mmm, sound like a case of beer ears (as opposed to beer goggles) to me!
Good result though by the sound of it - was it easy to switch over?
-oli
Audi A8/S8 D2 Flickr Group
Old 15th February 2009, 04:37 PM
Yes, just unplug all 4 conectors and plug them in on the other side.
BTW, was up at A8Parts last Friday! You getting excited yet Oli?
Old 15th February 2009, 09:02 PM
Oli18's Avatar
Oh man, i can hardly sleep! I don't think i'll be able to stop grinning when I get in and drive off
-Oli
Old 16th February 2009, 03:17 PM
Took the car for a run on the way home from work and the fault is back but not on the other bank! Cat and Engine management lights came on when I booted it and engine ran rough. Got home and used VagCom to find exactly the same codes. Random Misfires and Cylinder 5?
Wondering what to look at next?
