Old 15th February 2009, 04:37 PM
Yes, just unplug all 4 conectors and plug them in on the other side.
BTW, was up at A8Parts last Friday! You getting excited yet Oli?
Old 15th February 2009, 09:02 PM
Oli18's Avatar
Oli18 Oli18 is offline
Oh man, i can hardly sleep! I don't think i'll be able to stop grinning when I get in and drive off
-Oli
Audi A8/S8 D2 Flickr Group
Old 16th February 2009, 03:17 PM
Took the car for a run on the way home from work and the fault is back but not on the other bank! Cat and Engine management lights came on when I booted it and engine ran rough. Got home and used VagCom to find exactly the same codes. Random Misfires and Cylinder 5?
Wondering what to look at next?
Old 16th February 2009, 05:10 PM
Cable between amplifier and cylinder 5?
Old 16th February 2009, 05:18 PM
How do I test? Continuity from amps to Coil Pack?
Old 16th February 2009, 07:43 PM
if you can, put some crocodiel clips on with the tester and wiggle the cable.
Or... if it's easy enough to do, swap it to the other side and see if the misfire goes with it.
Old 18th February 2009, 08:43 PM
Well had a go at tesing continuity and all seemed well. Did some wiggleing and found nothing! Now the prblem is gone. Done 150 miles and nothing going wrong.
