Old 19th December 2018, 04:54 PM
johnny_quattro's Avatar
Default Back again
Water out of the rear vents is blocked climate drains, which will make the footwells wet on both sides as it also sloshes out of the main heater box via the ducts which feed the footwells and lower side vents. That's fairly simple to fix by taking the two centre console panels out and cleaning out the orange tubes.
Botangs hole is water ingress behind the glove box and just drips on to the fusebox on that side.
I've just dug out this age-old thread as my water ingress problem has returned with a vengeance. The description above perfectly describes my current situation, so thanks MJ for these nuggets of information.
The orange squidgy things certainly seem to me to be a design fail on the part of Audi. I'm expecting that a 3D-designed replacement part would fit the bill but the material the current part is made from probably negates any possibility of this being achievable.
Has anyone attempted to replace these orange parts either side of the transmission tunnel?
