Old 21st September 2016, 01:36 PM
Zip's Avatar
Zip Zip is offline
Question
Originally Posted by Zip View Post
Right....decided to tackle and fill botang's hole. Which was a lot less difficult than everyone has lead me to believe, but that clearly isn't the problem.
Got some Mr Muscle in my grocery delivery which I will try on the main scuttle drain tomorrow. Failing that I'll get some bent brake pipe and hose.
Sucked as much water out of scuttle and carpets as I can with the VAX.
But....question? If I knock up a small enough fitting, can I shove a pipe through the front and rear vents inside the car and try and suck out the remaining water with the VAX? Or am I going to damage something in there? Some major sloshing still going on. Or, if I disconnect and clear the orange drains running through the cabin either side of the transmission tunnel, will everything drain out on its own? I suspect I know the answer
Thanks,
Back to the top...any ideas please?
Thanks,
Zip
