Old 23rd March 2010, 06:52 AM
Originally Posted by Mr K View Post
Bloomin excelent! You must be extremely pleased with this!
A couple of quick questions;
- does all the wood on the doors come out simply by carefully levering it? i assumed i would have to remove the door cards to get the grab handle bits out.
- Did you wet vac the alcantara inserts in the door cards? they look spotless! My drivers door card has a couple of marks / scuffs from people getting in and out. I have access to a wet vac as my brother does carpet and upholstery cleaning, but was worried to use it on the alcantara.
Edited to add:
would love a ride in it, even just to head how quiet mine is! there seems to be a hell of a lot of road noise in mine; it seems no quieter than my girlfriends 1999 polo. hopefully new suspension arms will stop this.
1) - No need to remove door cards for a wood change. The strips across the top literally just prize out. Then, remove the lower half of the door handle insert by prizing gently with a flat blade of some kind and when it comes out it reveals 2 x cross head screws. Remove these, and the wood door handle insert will also come out with some prizing...
2) - Nope, I chickened out on the alcantara - They're not quite as good as the photos make them out to be unfortunately, but I always figured those bits I could get professionally cleaned at a later date if I felt like it. The carpets were main problem area and they came up a million times better...
