Old 24th August 2010, 08:42 PM
Oli18's Avatar
Oli18 Oli18 is offline
Hi,
This may be useful.
http://forum.a8parts.co.uk/showthrea...1456#post11456
Oli
Audi A8/S8 D2 Flickr Group
Old 24th August 2010, 11:19 PM
RanjS8 RanjS8 is offline
Default abs problem solved....
Thanks for your replies....
well guys turns out that when i pulled the abs sensor...there was lots of rust type debris that had built up inside the housing....and unfortunately i didnt bother cleaning the inside of the housing....now when i was putting the sensor back in, because it was such a tight fit I tapped the sensor back into place....as i was tapping the sensor all the crap in the housing was coming loose as dust particles.....now this is the key point...the tip of the sensor is magnetic so the dust particles were sticking to the sensor....therefore unknown to me my nice clean sensor was becoming dirty as I was knocking it back into place....which led to my dirty abs sensor problem...which presents itself as a jerk noisy stop.....
so now i finally managed to get the sensor back in place without getting them dirty...however I m sure at some point i m gona have to pull the hub bearing housing off to get all the rusty crap out......
Before i pulled the sensors, I didnt have a problem....I just thought might be good idea to give the sensors a clean while i m doing the rear brakes....but in trying to solve this problem i ended up taking the brakes on and off three times...which hasnt been the most exciting thing to do in the world....so i think the moral of the story is....'Don't try to fix something that ain;t broke.....just leave it be....'
