Old 21st June 2018, 04:52 AM
Chip2786 Chip2786 is offline
For it to break enough to report as not installed, but not enough to break the fibre loop seems like a long shot to me...
Mine did
Jobs done so far;
Fitted an RS Steering Wheel, Fitted 15mm wheel spacers, Lowered 10mm with VCDS, Reinstalled factory DVB, Unlocked VIM, Updated MMI to 5570, Fixed Factory Bluetooth Phone, Fitted heated fan-spray washers, Installed Bluetooth DAC For Audio, Added projection Puddle lights, Wind Deflectors, Fitted Apple TV to all 3 Screens, installed car WiFi, Fitted Custom vortex Exhaust
Old 21st June 2018, 09:26 AM
Originally Posted by Chip2786 View Post
Mine did
I know.... thats why I went for 'long shot' rather than impossible.....
Old 21st June 2018, 09:31 AM
Conquistador's Avatar
Thanks all. Carpet is easy enough to take up so I'll do that to start with and see whats what under there at the weekend.
Still haven't fully got my head around RSAP, whether I have it, need it or want it but I understand it might solve the connectivity / signal issues.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 22nd June 2018, 08:42 AM
The original Bluetooth phone ECU in A8s was the 'Handyvorb2'; latterly I believe the 'BTA' [aka RSAP unit] was used instead.
The BTA is a 'better' unit as it uses an external aerial rather than the phone for reception, but although the Handyvorb2 and BTA are 'sort of' plug compatible, you can't easily replace the Handyvorb2 with the BTA as you won't have the external aerial you need.
Handyvorb2 HW part number is 4E0 862 335; it has 3 connections - electrical, optical & BT aerial.
BTA HW part number is 4F1 862 335; it has 4 conections - electrical, optical, BT aerial & external aerial.
Julian
Audi A8 3.0TDi MY2016 in Nautilus Silver.
Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years!
Old 22nd June 2018, 08:57 AM
Also - RSAP is a mixed bag - effectively your SIM card is virtually disconnected from your actual phone and connected to the car which has it's own cellular chip-set. This means your mobile is not connected to the mobile network any more, the car is!
Upshot is this is great for standard voice - most likely 2G - as the "car phone" used external antennas etc.... But useless for anything else!!!!!! You mobile won't have any data connectivity, SMS/Messaging etc and you end up with two call logs also
I use RSAP on the D4 as it is integrated with the navigation/google maps - it is bearable as there is a wifi hotspot in the car which used the "car phone" to provide data, so you an fudge by using wifi on your mobile to get some access. But even then, it is at maximum 3G speeds and tends to be cludgy.....
S4 & RS4 both have standard bluetooth, in some ways so much easier and no signal strength issues, with the roof down!!!!!
Old 21st June 2018, 11:26 AM
Just as an aside, the same issue affects the VW Passat (maybe other VWs as well). My brother couldn't get his phone to connect despite BT being installed and active. The proposed solution found on one of the VW forums was exactly the same... disconnect it, cycle the ignition, reconnect, and try again. Unfortunately, his still won't connect.
Old 21st June 2018, 12:33 PM
Have you been tinkering in the green menu? Seems odd that the fitted and working module now is not assuming its dry etc.
Have you tried another possibly older phone to see if it works?
Old 21st June 2018, 01:21 PM
It says telephone is not installed (i.e the module) rather than telephone is not connected, i.e. when the module is online but there is no phone connected to it....
Old 21st June 2018, 10:04 PM
I can also confirm that my A8 phone unit went bad but left the MOST Bus working. Only noticed when the phone icon wasn't on the bottom of my MMI screen.
When I checked, I had the same symptoms as the OP; 'Telephone Not installed' messages on the MMI screen and 'Cannot be reached' messages in VCDS for Address 77.
Lifted the carpet and no signs of water ingress; opened the ECU case but no visible issues. But had to fix it by replacing the unit with a cheap eBay replacement.
Julian
