If I paint mine it will be body colour, but raw aluminium will probably be more subtly stylish.
Would it not be wise to add some sort of gasket to the back of these to prevent rubbing and reduce the risk of any long-term damage?
It barely moves now so any sort of wear will be negligible I think. Plus adding any kind of compressible material in there would reduce its effectiveness.
I've installed the MJ brake block upgrade. It fitted perfectly. Once the strut brace was bolted back in place, I didn't see any movement. I could definitely feel more bite to the brakes but I was only driving around in my residents car park area, due to the current lock-down. Apologies for no photos in situ as my phone battery died.
2010 B8 S5 Sportback quattro 3.0 Supercharged in Sprint Blue (current girlfriend) 2000 D2 A8L quattro 4.2 in Audi silver (my ex-girlfriend) |
Just fitted mine too. The cover fits back OK without any trimming, though mine was already missing one leg of the clip onto the strut brace so does have more freedom to flex.
Maybe it was brain fade but at first I couldn't get it to slip into place and thought I'd have to take the whole strut brace out! ![]() But just remove both bolts completely and lift the end of the brace up a few mm; that gives just enough room to wiggle the block in from the centre of the car. It can't go in from the outside due to the taper on the brace. ![]() A very snug fit; with the bolts just hand-tight there was a 1-2mm gap between the brace and it's mounting. The bolts tightened up very satisfactorily with the block then firmly locked in place. ![]()
I removed the 2 bolts from each end of the brace, moved it towards the near side, slotted the block onto the brace and then reversed the procedure. No issue with the fit or any fiddling about.
After a couple of fairly short test drives, the peddle travel is definitely reduced and the ‘sponginess’ is reduced a lot as well. Much more confident braking and an absolute bargain at £30!
