Old 19th November 2010, 02:10 PM
Red face
That basically means one of the sensors is duff. Vagcom can tell you which one... You can reset the fault, and it will maybe work again, breifly, but really it will need a new one... Its not uncommon unfortunately.....
In this weather there is small chance that grit and crud from the road can coat them and cause duff readings, a good clean might afford you a little more time with it...
Sensors are only about £50 i think, and its not too hard to fit them...
The parking sensor seems to be coming and going, so I might try a clean. Is it just the small round face on the bumper or is there something else to clean?
And I don't suppose there's a thread on replacing them is there?
