I thought, after all its been through, the car deserved four of the stupid-expensive rivets
![]() The stump of the old stud Ground it off and drilled a 5mm hole for the rivet At this point it went catastophically wrong, and my air rivet gun totally destroyed a £12 rivet ![]() ![]() I also replaced the starter cable stud with a rivnut which is a mod I've been doing for a while Broken earth bolt Drilled it out and ran a tap through it to clean up the threads. Logs of galvanic corrosion on here so I'll clean up this surface as well. Also replaced a couple of other broken rivnuts with new ones, and cleaned up the others with a tap |
