Old 16th August 2021, 02:19 AM
27litres's Avatar
27litres 27litres is offline
and then the new timing belt kit
Looks quite different to the FL timing belt arrangement!
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 17th August 2021, 09:35 PM
Its a similar concept, but in the 32V the timing belt is driving the oil pump (lower left) so the belt routing is a bit longer than the 40V which has the oil pump driven from the crank.
The wheels are back from refurb:
Nearly finished cleaning
Tunnel before
and after
The stud by the power cables broke off as usual
Drill a hole
and fit a rivnut
This stud gets in the way of removing the servotronic rack but conveniently broke off when I removed the plastic nut, which is actually a bonus
Drill it out
and fit a rivnut again. This one protrudes in to the raintray so its a blind rivnut rather than the open type, and bedded down on seam sealer
The PS fluid has got in to the seam sealer here and dissolved it
Fish out all the sticky stuff with a pokey tool
Fill in with new seam sealer
Plotting to fit an FL upper brace so that I can also fit a brake block. Given that the PF S8 has the same brakes as the A8 I think it definitely needs all the braking help it can get, and the HP2 calipers with a brake block is a decent enough system.
The ESP return hose is in the way so I will fit an FL hose here
ID:	26945   Click image for larger version
ID:	26946   Click image for larger version
ID:	26947   Click image for larger version
ID:	26948   Click image for larger version
ID:	26949   Click image for larger version
ID:	26950   Click image for larger version
ID:	26951   Click image for larger version
ID:	26952   Click image for larger version
ID:	26953   Click image for larger version
ID:	26956   Click image for larger version
ID:	26957   Click image for larger version
ID:	26958   Click image for larger version
ID:	26959   Click image for larger version
ID:	26960   Click image for larger version
ID:	26961   Click image for larger version
ID:	26962   Click image for larger version
ID:	26963   Click image for larger version
ID:	26964   Click image for larger version
Old 17th August 2021, 09:59 PM
Nice wheel refurb - but 245/40s, not 45s?
Old 18th August 2021, 06:48 AM
Yeah. I only spotted it while I was stacking them up after they came back from refurb and was wondering why the four contis were smaller than the dunlop spare I didn't even spot it while I was applying the tyre dressing.
Its frustrating because these are only a couple of years old and barely half worn so I wasn't expecting to have to change them, but they're not right and so will be coming off. If I find a buyer before its finished then they get to choose what tyres go on. If not, I'll fit something I like.
Old 18th August 2021, 06:13 PM
Superb finish. Do the PF cars get an extra dollop of paint in the engine bay?
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 18th August 2021, 06:56 PM
PF and FL1 are lacquered in the engine bay so come up much better than FL2s which aren't.
Old 18th August 2021, 08:25 PM
How to fit a brake block to a PF...
Don't need this for a start - its not doing anything and in the way
The ESP return hose is also in the way. Interestingly that goes from the front of the reservoir straight to the rear chamber which was unexpected. Of course having just filled it with fresh fluid I now have to remove most of it Never mind. Its not expensive.
Remove this connection and the one from the hardline on the other side, being careful not to spill any fluid on the nice clean paint!
FL hose on the top, PF on the bottom. The PF hose is just a bit of plain clutch hose, whereas the FL is deliberately moulded to clear all the stuff in the way, such as the brace.
With the hose and superfluous bracket removed there's room for the brace hardware
Test fit with a brake block
Clamp in place to mark the holes
This is the rivnut tool. It'll set up to M12 without a problem.
Five of six rivnuts in place, but the last one is blocked by the bonnet switch. This bracket is to the far left of the frame on the FL, clearly moved so they could get tool access to insert the rivnut.
This one will need to be set the old-school way. The nut in the middle compresses the rivnut against the larger nut at the left, allowing it to be set with spanners in a much smaller space than the big tool needs
Hold the bolt and the large nut with two spanners while tightening the small nut with the 3rd spanner
Done
ESP hose back on
Proper clearance now
Bolted in place with the brake block
Brackets left in place but the bar is removed as it needs to be out to replace the wiring harness when the engine goes back in. The inner bolt for the bar is still a little tight on the bonnet switch, but its not like the bar comes out very often so it won't be a problem
I've never seen this done before, and these parts are only listed for the FL so this might be the first PF with an upper brace and brake block?
ID:	26967   Click image for larger version
ID:	26968   Click image for larger version
ID:	26969   Click image for larger version
ID:	26970   Click image for larger version
ID:	26971   Click image for larger version
ID:	26973   Click image for larger version
ID:	26974   Click image for larger version
ID:	26975   Click image for larger version
ID:	26976   Click image for larger version
ID:	26978   Click image for larger version
ID:	26979   Click image for larger version
ID:	26980   Click image for larger version
ID:	26981   Click image for larger version
ID:	26982   Click image for larger version
ID:	26983   Click image for larger version
ID:	26984   Click image for larger version
ID:	26985   Click image for larger version
Old 19th August 2021, 10:38 AM
Done
More attention to detail. Most mechanics would just bend the switch bracket out of the way to use the rivnut tool. As for the spanners, are you tri-dextrous?
Old 19th August 2021, 11:12 AM
It didn't even occur to me to bend the bracket
If you get the orientation of the bolt and larger nut right then both those spanners can be held with one hand while tightening the smaller nut with the other
Old 20th August 2021, 08:06 PM
More rivnuts This is what remains of the screw holding the airbox trim
grind the stump down so I can get a drill on it
Drill out the bolt and the top bit of the rivnut
Remove the rivnut
Ta dah!
One in the front of the wing for the front bit of the same trim
(yes, I did change the bolt for a not-rusty one )
and one over by the header tank for that cover
ID:	27001   Click image for larger version
ID:	27002   Click image for larger version
ID:	27003   Click image for larger version
ID:	27004   Click image for larger version
ID:	27005   Click image for larger version
ID:	27006   Click image for larger version
