#31
No point in having a filter if you can't clean/replace it.
#32
It will get the car through the 3 year warranty period on long life intervals, thats all they care for.
I have removed them on my 2.8 as per MJ's advice and have no regrets, the £37 chinese tensioner is holding up well. |
#33
Good to know about the 4.0T engine, it's what I was thinking of if I went with an Audi when I next need a vehicle.
#34
Seems to have just gone "live" in UK!
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 5th May 2022 at 05:06 PM. |
#35
Thats really interesting to read, looks like as you say the recall is now live in the UK for the 4.0TT.
Handy to know as a D4 S8 would be an excellent daily driver.
-- 2001 Audi A2 1.4 SE - Jaipur Red Pearl -- |
#36
I wonder what exactly they'll do on those engines where the filters are clogged, and have partially starved the turbos of oil. Will they just fit new filters and send the owner on their way, and leave them in the lurch when the turbos fail?
And what about those owners on this side of the pond that have already had the substantial expense of having to replace their turbos due to a problem that Audi have been aware of for some time!
#37
I did the bank 2 tensioner last night - that was also in perfect condition, so filter removed and new pads fitted, then back together
The front crank seal was weeping a little so that needs changing Pull the bushing out with a couple of magnetic pick-up tools Cleaned up ready for the new seal I made a new tool for fitting the seal as my previous one wouldn't push them in straight. This one pushes the seal properly square by using the sprocket bolt, similar to how the factory tool works, although mine still assembles the seal and bushing together rather than putting the bushing in later. All done Torque the new sprocket bolt to 200Nm + 180°, then put the new belt kit on Ready for the inlet manifold I discovered some time ago that the factory put sealant on both sides of the inlet manifold gasket, so I do the same. Manifold back on It cleaned up quite well Aux belt rollers back on and the engine is pretty much done for now Gearbox tomorrow ![]() |
#38
Does it come out that easily?
Is that part number 077115147A (radial shaft seal), as it seems to be from the old ETKA diagram? Is there a part number for the seal or do you reuse it? Also, does it matter that it's the other way around (text stamped on it but not on photo further up)? How do you torque it up to that crazy figure?
#39
Yes The bushing has to be flipped around when replacing the seal so the new seal runs on a new surface, as the old one wears a groove in to the steel. The writing on the front is an imprint from the oil pump sprocket, which was on the back. In theory you'd probably need to replace it by the time the engine is on its 3rd seal, but we probably won't be allowed to burn dino squeezings any more by the time that comes around anyway. Well, I like my food and I have a long bar ![]() |
#40
![]() ![]() Edit: Looking at picture 4 of 12 above you can see where it came from!
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 9th May 2022 at 06:47 PM. |
