Does it come out that easily?
Is that part number 077115147A (radial shaft seal), as it seems to be from the old ETKA diagram? Is there a part number for the seal or do you reuse it? Also, does it matter that it's the other way around (text stamped on it but not on photo further up)? How do you torque it up to that crazy figure?
Yes The bushing has to be flipped around when replacing the seal so the new seal runs on a new surface, as the old one wears a groove in to the steel. The writing on the front is an imprint from the oil pump sprocket, which was on the back. In theory you'd probably need to replace it by the time the engine is on its 3rd seal, but we probably won't be allowed to burn dino squeezings any more by the time that comes around anyway. Well, I like my food and I have a long bar ![]() |
![]() ![]() Edit: Looking at picture 4 of 12 above you can see where it came from!
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 9th May 2022 at 06:47 PM. |
Sunday's update on Monday. Mike came over and we did the gearbox service and reseal.
Clean sump pan, although the magnets are in the wrong places. Not much magnet fluff which is good. Sump off and filter removed Prime the oil pump inlet The left output flange was leaking badly This is held in place with a bearing and circlip Press tool to spread the load while pushing the shaft out It sits in the vice like this Pushed out. I can swap the seal and bearing, then put it back together New F125 Engine and box back together This evening I cleaned up and refitted the wiring harness and coolant hoses |
The aircon pump pulley bearing is worn out and grumbly but I've had enough of replacing compressors just for this, with all the faff around emptying and refilling the system. So, replace the bearing...
The pulley is just held on with a circlip so slides off easily enough The bearing is pressed in and then staked to make sure it doesn't come out The usual contrivance of round chunks to push the old bearing out and to push the new one in This can be swapped for the one on the car after the engine is back in I pressure washed the subframe. Its in very good condition with a little surface rust I'll clean most of this with a wire wheel and then paint with rustoleum |
![]() Wonderful problem solving there on the bearing. ![]() And pleased to see the subframe is better than I expected (and the MOT advised?) Out of interest which exact Rustoleum product do you use? I also note re the leaking output shaft that I'm not alone.... http://forum.a8parts.co.uk/showthread.php?t=16666 And I remember the horrid smell of that stuff dripping onto the exhaust! ![]()
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 13th May 2022 at 08:22 PM. |
![]() Working on the uprights today. Start by cutting the top arms and tie rod end off to make access easier. The bolt was obviously seized so I snapped the head off and started jacking the stump out using the nut instead Keep adding washes and spacers until its almost out The remains This is where the insert came out. Someone has attempted to break the taper by hitting it with a hammer, as is often the case, and bruised the aluminium housing which has distorted the hole slightly, loosening the pressed-in insert. Cleaned up with the rotary tool Loctite 638 to hold the insert in permanently Bolted in place overnight while the loctite sets up The other upright was not so cooperative and the bolt snapped at both ends, so I'm going to have to drill that out tomorrow ![]() |
