Old 21st March 2024, 05:38 PM
I opened up my broken manifold and you can see hear clearly where she broke.
ID:	30179   Click image for larger version
ID:	30180   Click image for larger version
Audi S8 D2 2002 88k mls
Old 22nd March 2024, 02:59 PM
I am wondering if it would be possible to remove the plastic flap, weld the broken arm, then securely reattach the plastic flap.
Old 22nd March 2024, 03:46 PM
Just looking at the photos again, isn't it a very unusual part to break? I always thought that it was just the plastic flaps that deteriorated over time, got brittle and broke off. Although, you could say he was 'lucky' in that there was no way part of the arm and the flap were going to drop into the cylinder, unlike small bits of plastic.
Old 22nd March 2024, 04:24 PM
The pads are actually a very stiff rubber not plastic. Still quite flexible in hand.
Old 23rd March 2024, 06:24 AM
Plastic going through the engine probably would not do any harm, if anything it would go through engine and get stuck in cat. It might just burn up in cat and not cause any issues or it may contaminate cat and make it less efficient.
On 4.0TDI I think the manifolds themselves are plastic, they age, wear and cracks over time and let the metal bits become loose which go in engine and wreck it.
Old 11th April 2024, 01:36 PM
So...... an update.
Got the NOS unit from the US but unfortunately it arrived with a broken vacuum pod. Seller was super helpful, perhaps a little too helpful and refunded me the cost of a new one which I got from sccuderia (£130).
The used unit I bought on Ebay which came from Germany (£180) ish seems to be in perfect working order. I've checked it with a hand held vacuum pump and all seems good and the flaps move nice and freely. I gave it a lick of paint to smarten it up a little.
After exploring my options I've decided to fit the German one for now. It wasn't my easiest of decisions as I'm a bit OCD about maintaining the car but financially it makes sense. Whilst ever I keep the US unit new it will maintain some value. Once fitted to the car it will obviously just become part of the car and it's value (£1400) will be lost.
I hope I don't live to regret that decision.
The other main reason for fitting the used unit is because I'm getting increasingly frustrated about how difficult it is becoming to find parts for the S8. My OCD is quite severe when it comes to maintaining my vehicle's. It's kind of my hobby and not being able to do it correctly bothers me. Consequently I keep flip flopping between keeping and selling the car.
ID:	30198   Click image for larger version
Old 12th April 2024, 02:26 PM
Does anyone know the torque setting for the bolts that hold the inlet manifold to the block please? My info seems to suggest 25Nm but that seems quite high to me for the size of bolts.
Old 12th April 2024, 06:38 PM
I used the following PDF from the D2 Tech dump post. According to the table on page 83, it's 10Nm. Link as follows, and would have been the document I referenced when working on mine last year:
Service Manual 8-cylinder engine (3.7 ltr & 4.2 ltr 5-valve AQF, AQG, ARU, AUW, AVN, AVP, AKC, .pdf
