Old 14th January 2014, 07:21 PM
Definitely looking good man, that colour is lush,looks deep enough to swin in.
Old 24th January 2014, 06:37 PM
Oli18's Avatar
Oli18 Oli18 is offline
Thanks - it's definitely one of the best features
looking good Oli, just realised your number plate suggests your car started life as a Scot
I think you're right but how can you tell?!
Oli
Audi A8/S8 D2 Flickr Group
Old 24th January 2014, 08:55 PM
Reffro Reffro is offline
This will help..
http://en.wikipedia.org/wiki/Vehicle...as_territories
Old 24th January 2014, 09:20 PM
indeed anything starting with "S" is from up here, hope you intend bringing it "home" in June??
Old 13th February 2014, 06:24 PM
Oli18's Avatar
Default Bag hook
Haha - it's my wedding anniversary so doubt i'll get away with it...i might try and float it past Mrs Oli18 after i give the valentines flowers!
I've not managed to do a whole lot on the car recently as I have enjoyed driving it to Holland for 2 weeks earlier this month. I did however go ahead and retrofit a couple of grocery bag hooks for in the boot so that it stops the weekly shop from flying across the boot on the way home
Part number 1K5867615 - there are eBay equivalents i.e. here - and fitted them last weekend to both sides.
Oli
Old 13th February 2014, 06:30 PM
Oli
I have those bag hangers in the boot of my D3, are they extras then?.
Old 13th February 2014, 07:20 PM
Thanks for that Oli
Just went to check it and I've got them
You learn everyday....
Old 13th February 2014, 07:24 PM
Hi
Ian - i'm so glad I didn't make a change when i first got it...i wouldn't change it for the world now!
PhYcHe - They are Delta Mics hub centric wheel spacers. They are made of steel rather than aluminium alloy - unlike my previous Eibach and H&Rs which were are about 2lbs lighter but i wasn't that bothered - the important thing for me was that it had the TRACK+ configuration where you first bolt the spacer to the hub and then the wheel on top rather than replacing the bolts with longer ones.
So another quick update on mods...I finally got around to fitting the CREE LED P21Ws and 501s, wiring and coding them as DRLs and OMG, what a difference. The photos don't quite do it justice but the difference is quite remarkable. It may be one of my favourite mods so far. It makes the car look much fresher, newer and up-to-date...and it's not really that old yet either!
I wanted to thank M-A8 for his DRL retrofit 'how-to'
Cheers,
Oli
Before: (Sorry for the crummy pic...it's the only one i could find...doh!)
After:
Great stuff Oli
What a difference !!!
By the way, where is the S8 grille mate ???
Can't wait to see it on your car.
You could consider this http://forum.a8parts.co.uk/showthread.php?t=7526
Old 13th February 2014, 07:33 PM
Oli18's Avatar
Still haven't got around to it....it's been a little on the rainy side (not sure if you've seen the news ) so have put it off until the weather gets better
Oli
Old 13th February 2014, 07:39 PM
By the way, I don't know if you've noticed, but it clearly says NO PARKING
Tags
4.2, audi, tdi
