Old 2nd September 2014, 10:37 AM
Originally Posted by jools_s8 View Post
Thanks for the reply. I could not get enough of the stand on the sill without risking damage or worse the car coming off the jack.
Don't use the sill to jack off as it'll just fold in. I've always put the boot jack at the rear jacking point wound it up a touch so you can get you trolley jack under the front jacking point, pump your jack up so you can fit the axlestand under the subframe.
As I think I've mentioned in another thread, I use the standard jack to lift the car an inch or two then slide the trolley under. They use different locations so it's no problem.
Where do you use for the trolley jack just out of interest?
