Old 16th December 2009, 02:16 PM
Mkoneman's Avatar
Mkoneman Mkoneman is offline
Haha 2 words: wipe clean
www.facebook.com/obdworks
full genuine ross-tech vcds
full genuine vag- tacho
Old 6th February 2010, 09:50 PM
Oli18's Avatar
Oli18 Oli18 is offline
http://cgi.ebay.de/Audi-A8-D2-Sitze-...item4838760de0
I would love to buy this
I wonder if he would have the wiring loom, door buttons, parcel shelf and if it's from a non Limo version...
Wish i had more time and money
Oli
Audi A8/S8 D2 Flickr Group
Old 15th February 2010, 12:00 PM
Default Forward progress at last....
Ok, so we had some reasonable weather on Sunday, so time to get cracking on this project before I forget completely where all the bits went
So, Heres how my car looked at lunchtime....
And then by 3 pm:
And here is the carpet out of the car, sat next to the one that is going to go in. The original is closest to you, the new one furthest away. The front of the car is the to left of the picture, the rear to the right. Note that the rear of the carpet to go in extends by about 3 inches. This makes the car carpetted underneath the rear seats when the seat base lifts up and slides out. It wouldnt be the end of the world if you didnt have the carpet to install, but I do, so I shall.... After its given a dam good clean though !
Now the carpets are out, the next job is re-wiring. Wiring for this transplant runs the full width and bredth of the car. It connects to the ditribution panel above battery in the boot, into both rear doors for the new switches, into the passenger front door for the passenger seat memory, under the passenger seat for the memory and control for sliding the seat forward from the rear, and then theres the controls on the dashboard for lowering the rear headrests and the heater controls at the rear of the center console for the rear seats. I'm also fitting the wiring for the blinds whilst I'm at it.......
I previously dismantled the donor car loom and put it into neat, logical bundles but the weather has been so crappy lately its taken way longer to get going and I've forgotten what most of the wires did <doh> - Never mind, the wiring diagrams are excellent for these cars and after a few moments of pondering, I was back on track.
I've got a few logistical problems with regards to actually bolting the new seats in. The rear seat base is essentially the same for both cars, but then they are tailored by hand to spec, so there are some welds / threads / recesses that are missing / spare / excessive and I have to fix, but theres nothing too bad. The biggest pain I've got at the moment is I'll probably have to remove the LPG tank from the boot to get proper access to the rear buldhead, cest la vie .....
More updates towards the end of the week hopefully when I might get chance to get the soldering iron out and make some wires actually do something
ID:	742   Click image for larger version
ID:	743   Click image for larger version
ID:	744   Click image for larger version
ID:	745   Click image for larger version
Old 16th February 2010, 09:51 PM
CliveH's Avatar
CliveH CliveH is offline
Looking good there Ian
Present: S4 B8 avant, fully loaded, MRC Stage2, Milltek non-res, KW springs
Past: S8 D2 FL, S2 ABY coupe, RS6 C5 saloon, RS4 B7 saloon, S4 B5 saloon, S4 B6 avant, all gone but not forgotten
Old 20th February 2010, 08:20 PM
ok, we have a little more progress. I've also taken some slightly better photos (which I've resized you'll be pleased to hear) to try and explain some of the battle that lies ahead....
So, firstly here is a shot of a mockup of how the left hand side adjustable seat base sits on the car. Also there is a central plastic section that houses a large number of electrical connections. This sits inbetween the two moving seat bases when all installed.
Here is a shot of the other side of the car, without a seat base. I have highlighted the 4 holes where the base fixes. The front two are absent by default, and I've already used some rivnuts to fil these in (M8) and so they're not a problem. Bolt number 3 (top right) is a standard seat belt fixing from the regular seats, but number four (top left) is just a gaping inch wide hole as you can see. Its not the end of the world, I'm making a metal bar to insert into the hole with a suitable thread through the middle. This will give a nice tight fix within the box section....
These are the hooks that hold the standard seats on, but I wont need them when I convert so I have to remove them. This is d-day, once I cut these off, I *have* to make this work as there is no going back... !!
The hooks (green circle) are fixed to a plate which is essentially rivetted in, so I'm just going to drill out the rivets and they should fall out nicely....
The red circles are where the rollers for the moving rear seats are placed. There are two pairs of rollers per seat, this is a nice easy bolt through and tighten up - phew. The blue circles are some more absent lugs that I need but dont have. These will hold the upper center of the seat, which contains the armrest etc. This section is lower than the boot floor so I cant get behind it as I will hit the fuel tank, so its going to be a couple more rivnuts and screw in a thread that I can then screw on to....
Here is one of the 4 sets of rollers that will fit in the red circles
To sort this properly, and also to gain access to run the wiring looms and new RNS-E Tv Tuner etc I had to remove the LPG tank from the boot, hence the straps hanging in this boot shot. I've also hightlighted location of the rollers and hooks from the boot side. Note also the blatant cut out for the ski hatch, making retrofit a doddle if you so fancied.....
Wiring will be the next big priority, now I'm happy it can all be physically done without too much hassle....
ID:	755   Click image for larger version
ID:	756   Click image for larger version
ID:	757   Click image for larger version
ID:	758   Click image for larger version
ID:	759   Click image for larger version
Old 20th February 2010, 10:19 PM
CliveH's Avatar
This is turning into quite a mammoth task Ian! Great stuff and top write-up as usual
Old 21st February 2010, 10:00 PM
gninnam gninnam is offline
Looking good (rather you than me)
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
