Old 30th May 2016, 05:32 AM
Oli18's Avatar
Oli18 Oli18 is offline
Don't give up Ian she'll be worth it in the end!
Audi A8/S8 D2 Flickr Group
Old 31st May 2016, 10:30 PM
I'm plodding on. Spent 4 hours today refitting the glovebox.... The cable from the release button was knackered and glued together, and the glovebox was bent and didn't align properly. Arrrgh. Anyway, all done now.
So, to make me feel better here's a list of what's been done so far:
  • Oil / filter change
  • Spark plugs
  • Wiper blades
  • Coil packs
  • New MAF
  • Replaced and cleaned throttle body
  • New battery
  • A/C regas
  • Replaced n/s cat and Lambda sensor
  • All previous rear seat entertainment removed
  • Fresh alcantara headlinings fitted
  • Passenger seat memory fixed
  • PIN retrieved for the RNS-E
  • Diversity antenna checked and verified ok.
  • Front door cards sorted, and soundproofing reinstated.
  • Reversing camera removed
  • A/C drains unblocked
  • Heated windscreen fitted and wired correctly
  • Climate module diagnosed: bare, touching wires sorted, and refitted correctly + done basic settings
  • RNS-E refitted correctly
  • Number plates attached
  • Rear armrest fixed properly
  • Broken handbrake trim replaced
  • Broken sunroof control replaced
  • Engine ECU/Clocks replaced, which fixed an annoying fuel gauge issue
  • Boot lid trims refitted correctly
  • Upper headlining trims refitted correctly
  • Passenger seat now bolted down. Yes. Really.
  • Rear seats reinstalled, and now actually bolted down too.
  • Fault with bluetooth phone module diagnosed and replacement on way
  • Reconnected solar roof as cables had been pulled out
  • Traced rattle in roof to broken sunroof trims
  • Refitted all lower dash trims using all correct fixings
  • Refitted transmission tunnels covers, using correct screws
  • Refitted passenger wooden footplate using correct screws
  • Faulty bonnet shut sensor fixed
  • Front Passenger door upper 2nd locking plunger removed to stop rattle
  • All TV aerials checked and verified working
  • Given it a 9 spoke spare wheel to match
  • Got 4 correct sized tyres to replace the ones that are on
+ Cleaned and hoovered as I've gone along to make it feel a bit more fresh
I still have 34 items to do on my list, 1 of which is 'fix engine' lol, which will take quite a bit longer than 'fit correct phone aerial', but hey ho, its forward progress
Old 31st May 2016, 10:33 PM
How long before you sell it?
Old 31st May 2016, 10:45 PM
I admire your perseverance with this. You'll really have to go to town with the photos when it's complete.
Old 31st May 2016, 10:50 PM
I haven't been taking many..... The memory of the mess is bad enough, without photographic reminders
Old 31st May 2016, 10:51 PM
Its not on the cards, and don't think it would be worth it anyway......
Old 31st May 2016, 10:58 PM
Have you started having dreams/nightmares about this? If so...
Old 1st June 2016, 06:08 AM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
And I thought the list of fixes on my project S8 was bad!
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 1st June 2016, 06:19 AM
Ian
You'll get there and it will be worth it. So much time was put into this car originally it will be great to see it back to its former self.
Old 1st June 2016, 03:04 PM
That's an impressive list, and reminds me of all the things I still have to do on mine.
I hope to see it at the meet.
