Old 9th February 2016, 07:30 PM
It feels like its in to a box section that appears to run the width of that section - you can't get to it from the inside at all as far as I can tell. The two grommets can be reached from inside as they are above the box section. I presume for water to leak in to the cabin that this box section is simply stitched to the firewall, rather than seam welded. I'll see if I can grab some pics by sticking my phone through the electronics hole before the plastic box goes back in.
