Couple of updates:
Managed to shove the thin shampoo tube that comes with my VAX in the air vents at the rear and took out another 200 ml or so of water. Did the Mr Muscle drain gel flush on the main scuttle....bloody miracle stuff! Poured some water in first, then the full 500ml dose of cleaner....then waited. Was a bit sceptical, but after about 10 mins, a raging torrent flooded out of the underside of the car....result. Just rinsed out with boiling water afterwards. Taken the passenger side transmission tunnel cover off and drained out about 500ml (!) from the drain on that side. Easy to do,as I had that side out when I installed my Dension 100 years ago. What should I stick down through the orange tube to clean it out? Seems very soft and fragile. How do I get the drivers side out? Do I need to drop the under steering wheel cover? Thanks, Zip
2002 D2 S8: Ebony Black over Platinum. A8L Comfort front seats in black ( ![]() ![]() 2005 B6 S4 Cabriolet: Ebony Black Pearl over Silver. RNS-E, Bose, heated seats, cruise control, retrofit aux-in, centre armrest, Milltek resonated exhaust |
Don't stick anything down the tube, take it out and clean it properly (easy enough); trim the cross-end slightly too to improve flow.
Drivers side is: small trim below steering column off, knee panel off (several screws including one fixing it to the side panel via a flimsy plastic bracket), side panel off. Worth doing.
Thanks, Zip
The fourth picture down shows the orange drains.
Once disconnected from the black plastic drain pipe you just work around the edge to pull it out carefully. There's an inner section that is a fairly tight fit either side of the hole through the transmission tunnel to the exterior and a large flat plate that seals against the soundproofing layer on the cabin side. Easier to get back in if you soften it in hot water first. Just pushes back basically with a bit of wiggling/adjustment to make sure it's properly seated. Had mine out many times now. Once you get it out it's obvious how it fits back in.
Z
All,
Just wanted to say thanks for all the advice. The whole lot is dried out nicely, and the car is back together. Took the opportunity to plug an aux cable into my Dension Gateway 100 while the side panels were out....don't know why I didn't when I fitted it... Footrest is a bit of a pain to take out, but took the opportunity to clean it and fine sand the plastic section....looks almost new again. Only challenge is that I notice that the screw fixing above the right hand cubby of the under steering wheel cowling has been damaged before, and I'll need to epoxy a small plastic panel or something in there to screw it back in to....bit of a faff. It's an odd fibre based material that gets very brittle. Zip
Suspect many of us have either found that broken by a previous owner or managed to damage it
![]() Jim did a thread recently on what he did to repair it ![]() http://forum.a8parts.co.uk/showthread.php?t=12180
Audi S8 2015, Daytona Grey |
However this link will take you straight to my solution, which was done with photographic assistance from Jim. ![]() Any questions, just ask here (or probably better in that thread as this one is about Botangs hole). It will probably be useful to post up a picture of your fixing (or lack of it) to see how bad it is and what solutions are suitable.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 8th October 2016 at 09:24 AM. |
It is bloody good stuff. Be sure to buy the '5 minute action' gel though, not to be confused with the drain foamer, which is useless.
