Old 19th September 2016, 07:45 PM
Zip's Avatar
Zip Zip is offline
Question
Right....decided to tackle and fill botang's hole. Which was a lot less difficult than everyone has lead me to believe, but that clearly isn't the problem.
Got some Mr Muscle in my grocery delivery which I will try on the main scuttle drain tomorrow. Failing that I'll get some bent brake pipe and hose.
Sucked as much water out of scuttle and carpets as I can with the VAX.
But....question? If I knock up a small enough fitting, can I shove a pipe through the front and rear vents inside the car and try and suck out the remaining water with the VAX? Or am I going to damage something in there? Some major sloshing still going on. Or, if I disconnect and clear the orange drains running through the cabin either side of the transmission tunnel, will everything drain out on its own? I suspect I know the answer
Thanks,
Old 21st September 2016, 01:36 PM
Zip's Avatar
Zip Zip is offline
Question
Thanks,
Back to the top...any ideas please?
Thanks,
Zip
Old 21st September 2016, 01:47 PM
I've read something online (in Audipages maybe) about sucking water out through a thin pipe fed into the rear vents, but I didn't do that.
Basically I just sorted out the various drain blockages and took out all the (easily removeable) carpets for drying.
Then I set the ventilation system to "floor" and maximum fan, closed all the front and pillar vents, opened the rear centre vents and just blew it out over a few journeys. Towels to catch the spray.
Lots of gurgling to start with but it all went fairly quickly.
Finally I used silica gel bags over a few weeks to really dry out the inside. As noted in another thread (ages ago) I actually weighed the bags so that I knew when they were dry (just sat on the boiler all day) and how much water they absorbed (typically overnight).
Old 21st September 2016, 01:49 PM
Thanks,
Zip
I know when I had this problem, I was amazed by how much water came out when I took off one of the orange drains. I suspect that there is probably still some debris still lying in the A/C tray, but I never thought of flushing it out at the time. When I refitted the orange drains, I cut about 2mm off the bottom of them to make that sort of cross-seal slightly bigger. My car sits out 24/7 and I've got big fir trees, and it's amazing how those needles work their way into the car.
Old 21st September 2016, 01:54 PM
I did the same on the seals.
But I now pay most attention to the big scuttle drain, testing and flushing regularly with hot water and detergent. No problems in ages (fingers crossed).
My personal opinion is that these (dirty) drains overflowing into the a/c condensate tray is the main cause of problems as any dirt can easily block those smaller drains.
In theory the a/c drains will only ever see totally pure water condensed from the a/c system. Reality is rather different.
Old 21st September 2016, 03:35 PM
Thanks,
Zip
Take a look at this thread and maybe give the bottle and pipe idea a try?
http://forum.a8parts.co.uk/showthread.php?t=3192
Old 21st September 2016, 05:20 PM
Zip's Avatar
Zip Zip is offline
Thumbs up
Now that looks like a bloody good idea...!
Thanks for quick responses
...wish me luck.
Zip
Old 22nd September 2016, 10:43 AM
Zip's Avatar
Zip Zip is offline
Thumbs up
Couple of updates:
Managed to shove the thin shampoo tube that comes with my VAX in the air vents at the rear and took out another 200 ml or so of water.
Did the Mr Muscle drain gel flush on the main scuttle....bloody miracle stuff! Poured some water in first, then the full 500ml dose of cleaner....then waited. Was a bit sceptical, but after about 10 mins, a raging torrent flooded out of the underside of the car....result. Just rinsed out with boiling water afterwards.
Taken the passenger side transmission tunnel cover off and drained out about 500ml (!) from the drain on that side. Easy to do,as I had that side out when I installed my Dension 100 years ago. What should I stick down through the orange tube to clean it out? Seems very soft and fragile.
How do I get the drivers side out? Do I need to drop the under steering wheel cover?
Thanks,
Zip
Old 22nd September 2016, 10:54 AM
Don't stick anything down the tube, take it out and clean it properly (easy enough); trim the cross-end slightly too to improve flow.
Drivers side is: small trim below steering column off, knee panel off (several screws including one fixing it to the side panel via a flimsy plastic bracket), side panel off. Worth doing.
Old 22nd September 2016, 06:34 PM
Zip's Avatar
Zip Zip is offline
Question
Eh? So the whole orange thing slides out, does it? Don't want to pull it and damage it.
Thanks,
Zip
