Old 15th May 2022, 06:17 PM
After a trying day with one pinch bolt yesterday, today went from bad to worse The bolt would not respond to the usual techniques so I had to drill it out
This was going reasonably well until the 9.5mm drill bit caught the hardened balljoint pin and snapped off deep in the hole
I had to get the balljoint pin out to go any further. Drilled down the centre of it
Then used a cutoff wheel through the slot to cut it in to pieces
It came out in chunks
I was able to free up the drill bit, although it took a small chunk out with it - that'll get welded up before it goes back together
This upright is bruised around the lower arm inserts as well. So much so, in this case, that the sleeve is now captive
The hubs were quite rusty and rough which could cause wheel balance issues
Cleaned up
Gave up after 6 hours of this and finished early.
ID:	28448   Click image for larger version
ID:	28449   Click image for larger version
ID:	28450   Click image for larger version
ID:	28451   Click image for larger version
ID:	28452   Click image for larger version
ID:	28453   Click image for larger version
ID:	28454   Click image for larger version
ID:	28455   Click image for larger version
ID:	28456   Click image for larger version
